sanjayakp
Jul 9, 2009 9:21 AM UTC
Error opening visual programmer
Posted on July 09, 2009 at 11:21
sanjayakp
sanjayakpAuthor
Apr 30, 2009 6:48 PM UTC
Posted on April 30, 2009 at 20:48
I installed ST toolset new program in windows 2000.
When I tried to open the st visual programmer, I recieved a message window saying ''Cannot load JICC_API Dll'' even before vis. programmer window appears.
And Then brings up the configuration setting. I choose my micro and say OK, but it brings up another window saying ''choose a valid configuration''.
Need your help.
sanjaya
________________
Attachments :
1.bmp : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0GG&d=%2Fa%2F0X0000000bWG%2F4uFRfIeyTmv2Fhi8VOfQlrXN6RHn3UOyqtFkgqLjqv4&asPdf=false
wolfgang2399
May 5, 2009 10:32 AM UTC
Posted on May 05, 2009 at 12:32
Hi Sanjaya,
Exactly the same happens to me - with win2000 and the new ST toolset (pack17).
Because I'm only using the programming mode (STVP), I've re-installed the STtoolset-pack15 as workaround and all the features work fine.
Nevertheless, I'm curious when STM will fix this bug...
Regards,
WoRo
sanjayakp
sanjayakpAuthor
May 6, 2009 6:23 PM UTC
Posted on May 06, 2009 at 20:23
Thanks a lot for the info.
Can you help sending me the link for stttoolset pack 15.
Thanks in advance.
sanjaya
wolfgang2399
May 7, 2009 9:40 AM UTC
Posted on May 07, 2009 at 11:40
Hi Sanjaya,
there are no known links to older versions. I tried to upload the whole file and to append it here, but I failed. :(
Most probably it is the best way you ask your local distributor.
Nevertheless I think you would really promote this forum when you make our highly devoteded moderators discharge their duties ...
Greetings,
WoRo
wolfgang2399
May 7, 2009 10:21 AM UTC
Posted on May 07, 2009 at 12:21
...succeeded in packing the file to a .zip file and attaching it here.
You only have to extract the enclosed file. :)
Regards,
WoRo
________________
Attachments :
st7toolset_Pack15.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzne&d=%2Fa%2F0X0000000bWH%2FOxuivRD88T_5Rnw4fnKGOFph5wW6lSxa8Oodkps5oBY&asPdf=false
wolfgang2399
Hi to all Users (as well as to the Moderators :-o)
I became aware of that my attachement from 2009-05-07 could not work because the file has been corrupted - sorry.
I'll try again to attach a .zip file of pack Hope it works now.
BTW: Even in sttoolset Pack 18 the experts of STM did not fix the bug...
WoRo
________________
Attachments :
st7toolset_pack15.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0G6&d=%2Fa%2F0X0000000bWF%2FEF28PEedOH1DQ4NCBEYxy.I5lfpXJa6NYxG05v8ImGU&asPdf=false
