randomguy
#error cpstm8 FlexLM System clock has been set back
i'm trying to build a project and appers the message below.i already checked the files date, reinstalled, cleaned registry.don't know what else to do..How can I fix that?!
----------- Project miami - STM8 Cosmic - Configuration Debug -------------
Removing intermediate files ... Done!
Compiling eeprom.c...
cxstm8 +modsl +debug -pxp +compact -pp -l -i"C:\Program Files (x86)\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ eeprom.c
#error cpstm8 C:\Program Files (x86)\COSMIC\FSE_Compilers\CXSTM8\Hstm8\modsl.h:1 FlexLM System clock has been set back.
eeprom.c:
 The command: "cxstm8 +modsl +debug -pxp +compact -pp -l -i"C:\Program Files (x86)\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ eeprom.c" has failed, the returned value is: 1
exit code=1.
miami.elf - 3 error(s), 0 warning(s)
    randomguy
    randomguyBest answer
    I had change the HD and reinstall the windows and software.. it worked.
    thanks for your time.
    July 28, 2020
    https://community.st.com/s/question/0D50X00009XkfZBSAZ/cosmic-license-error
    Get a decent file manager software and check thoroughly.
    Do a clean install, on a clean machine.
    Check current date/time reported
    What versions of windows, etc?
    randomguy
    randomguyAuthor
    Tks for reply
    I had download the latest version before install, had a previous version installed with the same error.
    I did the clean install in others two computers without any problem to check if was some problem with install files.
    In the three machines i'm working with win 10 x64.
    But in the computer that i need didn't work..
    randomguy
    randomguyAuthorBest answer
