kvest
May 17, 2010 4:09 PM UTC
Error configuring STVD to use cosmic compiler
Posted on May 17, 2010 at 18:09
    hsynenko
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    Hi vest.kyle,
    I had similar problem. I do not know how accurate a solution, but it worked for me...
    You must make the choice to toolchain while create a new workspace. Problem does not occur choice when starting project. I hope it will be help. I dont know what is root cause. if you can know, Can you share me?
