raffaele
May 15, 2007 12:42 PM UTC
ENABLE XFLASH ON ST10F276
Posted on May 15, 2007 at 14:42
raffaele
raffaeleAuthor
May 15, 2007 12:20 PM UTC
Posted on May 15, 2007 at 14:20
How can I enable the Xflash in this MCU? and how can I read the XFLAHS whit:
movb R0,R[1]
[ This message was edited by: invisigothux on 15-05-2007 18:01 ]
najoua
May 15, 2007 12:37 PM UTC
Posted on May 15, 2007 at 14:37
Hello invisigothux,
This is by setting XPEN bit in SYSCON register and XFLASHEN bit in XPERCON register.
Note: The XPERCON register MUST be written BEFORE the XPEN bit in SYSCON is SET because Register XPERCON cannot be changed after the global enabling of X-Peripherals, i.e. after setting of bit XPEN in
SYSCON register.
Regards,
Najoua.
raffaele
raffaeleAuthor
In boostraps mode, i can read the flash to the first byte of XFLASH.
If i try to read the Xflash like to read the iflash the MCU frezee.
whi ? There are special modality to read Xflash ?
After BSL secuence the Xflash is already set and enabled.Is correct ?
[ This message was edited by: invisigothux on 15-05-2007 18:16 ]
