sjackson
Sep 4, 2007 6:02 PM UTC
Enable/Disable Global Interrupts
Posted on September 04, 2007 at 20:02
mark9
May 17, 2011 7:44 AM UTC
Posted on May 17, 2011 at 09:44
Why are you using USER mode in main()? If you are using the default STR library, main runs from SYS mode. Look at 91x_init.s and ignore the comments (I hate comments like this. Most of the 91x library is littered with bad comments that are flat out wrong or misleading).
; --- Now change to USR/SYS mode and set up User mode stack,
MSR CPSR_c, #Mode_SYS ; IRQs & FIQs are now enabled
LDR SP, = SFE(CSTACK) & 0xFFFFFFF8
-Mark
