nmuthure
Oct 15, 2007 10:51 AM UTC
EMU3 emulator
Posted on October 15, 2007 at 12:51
EMU3 emulator
nmuthure
nmuthureAuthor
Iam using ST7Emu3 emulator for the project. When I try to start the Emulator Debugger ,status on status bar is toggling between RESET and RUN.
Also the RESET and RUN LED's are ON. I tried to modify the memory map as per my requirement and doing so triggers the error GDI error saying it cannot be modified to y config. I have used the same emulator for the same project before successfully.But I have lost the Settings.
Can anyone help me how to get around this.
