sab964
Jun 20, 2006 4:52 AM UTC
EMI /External Memory configuration and control pins
Posted on June 20, 2006 at 06:52
sab964
sab964Author
May 17, 2011 7:30 AM UTC
Posted on May 17, 2011 at 09:30
I have two questions connecting some external devices to the EMI interface:
1) Do the control pins EMI_WRHn, EMI_BWR_WRLn, EMI_ALE and EMI_RDn provide internal pull ups ????
2)I use multiplexed bus mode. Can I use one bank with 16 Bit data width and another bank with 8 Bit data width (set up with the two bit MW of the register EMI_BCRx) or must all banks use the same data width ?
Thank you again,
Wallie
anis
Hi Wallie,
I have the answer for your question2:
Yes , it is possible to have different data width 8 and 16bit for the two banks, in fact you have configuration registers for each bank for selecting the bus width.
For question1, I have forwarded your question and I let you know when I have the answer.
Best Regards,
STARM
