cstrahm
May 30, 2006 11:58 AM UTC
EMI Direct Pin Control ?
Posted on May 30, 2006 at 13:58
cstrahm
cstrahmAuthor
May 17, 2011 7:29 AM UTC
Posted on May 17, 2011 at 09:29
Is there any way to control the External memory pins from registers through code, or are these four pins solely controlled by the MCU internally? I'm not using external memory, but I could use a couple more general output pins. Anyway to make use of these?
anis
I suppose you are speaking about EMI control pins (EMI_BWR_WRLn, EMI_WRHn, EMI_ALE and EMI_RDn )
These pins couldn't be used as GPIO pins, they are only controlled by the EMI unit when doing external memory access.
Regards,
STARM
