EEPROM_I2c
I am using M24C04 chip and downloaded the software package EEPRAM2.
if(EEPRMA2_M24_Init(EEPRMA2_M24C02_0) == BSP_ERROR_NONE)
	 chip_ok=1;
	 // DOUBLEFLASH();
 else
	 chip_ok=0;
 if I used this instance it says chip ok=1 but the  read and write not working .As using M24C04 ,I also tried the instance as
if(EEPRMA2_M24_Init(EEPRMA2_M24xx) == BSP_ERROR_NONE)
	 chip_ok=1;
	 // DOUBLEFLASH();
 else
	 chip_ok=0;
it says the chip is not working
gbm
You forgot to show your code, so it's hard to help you.
Use HAL_I2C_MewWrite and MemRead family functions. They are described in HAL Reference.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
meenaAuthor
void testEEPROM()
 // Write data to EEPROM
 if (HAL_I2C_Mem_Write(&hi2c1, 0x50, memAddress, I2C_MEMADD_SIZE_8BIT, dataToWrite, 2, 1000)== HAL_OK) {
 // Handle Write Error
 i2c_write=1;
 return;
 // Read data from EEPROM
 if (HAL_I2C_Mem_Read(&hi2c1, 0x50, memAddress, I2C_MEMADD_SIZE_8BIT, dataRead, 2, 1000)== HAL_OK) {
 	i2c_read=1;
 return;
 // Check if the written data matches the read data
 if (dataRead[0] == dataToWrite[0] && dataRead[1] == dataToWrite[1]) {
 i2c_test=1;
 } else {
 	 i2c_test=0;
Hi I tried this to but i dont know why its not working
gbm
The EEPROM address should be shifted - 0xa0 instead of 0x50.
Andrew Neil
@meena wrote:
 the drivers not working for me.
What "driver"?
Hardware details?
Please see the Posting Tips:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
