jsayavong
Jun 12, 2006 4:08 PM UTC
EEPROM EMULATOR on STR71x family CPU
Posted on June 12, 2006 at 18:08
jsayavong
jsayavongAuthor
Jun 10, 2006 10:46 AM UTC
Posted on June 10, 2006 at 12:46
I am having a problem trying to use internal flash (bank1)as EEPROM of STR71x family microprocessor. Using a HITEX eval board (purchased from Keil) and I copied code which I downloaded directly from ST website --- the result was, system hung immediately when I ran it. Could some STR71 expert(s) in this forum kindly take a look at the code below and then please tell me what I did wrong here?
volatile unsigned long Data_Read;
volatile unsigned long Write_Status;
volatile unsigned long Read_Status;
int main (void)
EEPROM_Init(); //initialize EEPROM
// ------------ dataset#1 ------------
Write_Status = EEPROM_DataWrite(0x11111111); ///<< system hung begins
if (Write_Status == EEPROM_SUCCESSFUL_DATA_WRITE)
Read_Status = EEPROM_DataRead(&Data_Read);
if (Read_Status == EEPROM_SUCCESSFUL_DATA_READ)
printf(''The Valid Data-set is %x\n'',Data_Read);
// ------------dataset#2 ------------
Write_Status = EEPROM_DataWrite(0x22222222);
// ------------ dataset#3 ------------
Write_Status = EEPROM_DataWrite(0x33333333);
} //end main()
jsayavong
jsayavongAuthor
Jun 12, 2006 12:10 PM UTC
Posted on June 12, 2006 at 14:10
Thanks for the reply. I am very new to the ARM
enviroment. Looking into the reference manual you
suggested, I still can figure out exactly where
should the code be modified to execute from RAM.
Could you please kindly modify my quote per
your suggestion?
Thanks for your help in advance,
Regards,
JIMMY
jsayavong
jsayavongAuthor
Hi Sir,
I read the Note on section 2.3 but I am still not
be able to implement into my code above.
Do you have a ''known'' working code so that I can
try out on my eval board? to see if your theory is really
work? I am using KEIL UV3 compiler (REALVIEW).
My e-mail is:
mailto:jsayavong@perkinselectronics.com
if you
don't mind sharing your code.
Regards,
JIMMY
