Earth short protection TDA7498E
Hi, any suggestions to protect the speaker outputs of the TDA7498 from a short to mains supply earth?
Thanks!
Peter BENSCH
Welcome @just280, to the community!
If the supply voltage of the TDA7498 is galvanically isolated from mains, there should be no problem if one of the speaker output wires is connected to mains supply earth.
Does it answer your question?
/Peter
just280Author
Not sure that's a practical solution on a 170VA linear supply?
Peter BENSCH
Well, such a linear supply must also be galvanically isolated for safety reasons, or do you not have such isolation? Therefore the previous statement still applies.
