weigelt
Apr 19, 2005 2:44 AM UTC
double - variables
Posted on April 19, 2005 at 04:44
double - variables
weigelt
weigeltAuthor
Apr 8, 2005 3:40 AM UTC
Posted on April 08, 2005 at 05:40
Hi all,
I´ve got a problem using double-variables. They don´t get the values I try to write into. Here is my code:
#include ''71x_lib.h''
#include ''math.h''
int main(void)
double z,x,y;
debug();
x=2.0;
y=3.0;
z=pow(x,y);
while(1);
Very simple, but doesn´t work. The values I get are:
x=5.30498947741e-315 (should be 2.0)
y=5.30757980431e-315 (should be 3.0)
z=5.31599836671e-315 (should be 8.0)
Float seems to work, as long as I don´t try to use functions from math.h, because almost all functions of math.h expect double for their parameters. Is this a known problem?
Regards,
Marcus
weigelt
weigeltAuthor
Apr 8, 2005 3:42 AM UTC
Posted on April 08, 2005 at 05:42
Forgot to mention:
I´m using STR710FZ2T6 and RVDS2.1
weigelt
weigeltAuthor
okay, that´s not a problem, as long as i know, that these varaiables have the right value and it´s only a problem of the debugger to show them correctly. Thanks for your help ibtiss.
Regards,
Marcus
