alberto239955_st
Sep 6, 2006 7:07 AM UTC
dot matrix led display using ST7lite29
Posted on September 06, 2006 at 09:07
alberto239955_st
Sep 6, 2006 5:49 AM UTC
Posted on September 06, 2006 at 07:49
Hi;
I need to display an input signal (temperature from LM50) on 5x7 dot LED display. Display driver use serial comunication with a ST7FLITE29.
Does anyone have a suggestion where to see for application note or example code?
thanks a lot
fggnrc
tone,
this forum contains some code examples which show how to drive a 5x7 dot matrix lcd.
I however think that you should look for examples about the serial protocol.
The serial comunication needs a SPI, or I2C or UART unit?
Since ST7FLITE29 has only a SPI units, there is a chance you should implement a software routine that manipolates directly the I/O...
Bye
EtaPhi
