wolver
Apr 24, 2009 11:31 AM UTC
Does STVD suport static inline key to declare function?
Posted on April 24, 2009 at 13:31
    mozra27
    May 17, 2011 1:02 PM UTC
    Posted on May 17, 2011 at 15:02
    Hi wolver,
    I think this is related to the compiler:
    With cosmic compiler you can do this by the directive @inline
    With raisonnance compiler you can check the compiler option ''SPEED optimization'' and the compiler do this automatically
    mozra
    wolver
    wolverAuthor
    Hello
    ''static inline'' key to declare function have error in STVD. I know GCC suport ''static inline'', Then STVD?
    Redards
    wolver
    wolver
    wolverAuthor
    Hi _luca
    We have some short fuctions, such as following... If ''static inline'' can be used, The compiler obj has not push-pop stack.
    wolver
    PS: some short fuctions...
    void ModifyCurSystemStatus(unsigned char current_status)
    g_ucSystemCurStatus = current_status;
    unsigned char GetCurSystemStatus(void)
    return g_ucSystemCurStatus;
    void load_timer3_value(void)
    TIM3_CNTRH = 0x1E;
    TIM3_CNTRL = 0xFF;
    wolver
    wolverAuthor
    Hi mozra
    I use STM8 Cosmic, not raisonnance. But I should try to do it by the directive @inline ...
    wolver
    luca239955_st
    just out of curiosity: why would you want to inline functions ?
