jeffrey23
May 22, 2010 11:00 AM UTC
Does COSMIC support Little Endian approach ?
Posted on May 22, 2010 at 13:00
    swhite2
    May 17, 2011 1:08 PM UTC
    Posted on May 17, 2011 at 15:08
    (Post deleted)
    luca239955_stm1_st
    in addition to the considerations above, it is interesting to underline that, for a micro like stm8, who is capable of multibyte operations (ld.w), the endianness is forced by the micro itself (-> does not depend on the compiler): STM8 is little endian.
    Regards,
    Luca (Cosmic)
    swhite2
    Why do you care? If you had external peripherals on a bus I could understand but the STM8S103F3 doesn't have an external bus.
    If you need to send/receive data in big-endian order
    http://www.codeproject.com/kb/cpp/endianness.aspx
    to perform the conversion. That's what people have been doing on PC's (80x86's are little-endian) for decades.
    jeffrey23
    jeffrey23Author
    After doing some experiment, I found that the COSMIC compiler supports the BIG endian approach for STM8S103F3 as default mode. Can it support Little Endian approach ?
