dk5ug
Apr 12, 2004 12:51 PM UTC
DK3200 applications
Posted on April 12, 2004 at 14:51
DK3200 applications
simonharrison9
May 17, 2011 9:52 AM UTC
Posted on May 17, 2011 at 11:52
The errata released by ST for the DK3200 board fixes the problem.
(using old silicon too ! )
Simply change PC2 from Vstby to another function
Errata attached.
Simon
[ This message was edited by: sjh on 12-11-2003 16:17 ]
simonharrison9
Just an update, although my kit is up to date, it has old silicon on it.
Date code 0223
The November 2002 datasheet has a note on the last page discussing USB reset.
Devices dated after 0242 have the option to disable the USB reset action to the mcu/psd hardware.
This also means that I can not use PWM4 until it's changed.
This may be part of the USB problem we are seeing.
I will repace the device and give an update on the result.
Simon
[ This message was edited by: sjh on 12-11-2003 16:16 ]
simonharrison9
I have tested the code given above, by prancergokaka.
This works on a DK3200 V0.1 board, with no modifications.
I too have problems with the newer code, from www.psdst.com.
I will give more information as I find it.
Simon
dk5ug
dk5ugAuthor
date code here is 0245.
tong
May 17, 2011 9:53 AM UTC
Posted on May 17, 2011 at 11:53
Hi guys
Were the problems with the USB ever resolved?
Please let me know.
I am about to investergate the eval board.
dk5ug
dk5ugAuthor
Bingo!
My rev-0.1-board has 4.75k for R33.
I switched vstby off at PC2 and there we are -
Display is fine now and USB works!
I will replace R33 as next.
So I am on the road again with USB applications.
Thank you!
