marcus23
Apr 12, 2006 11:46 AM UTC
direct register access in c using IAR embedded workbench
Posted on April 12, 2006 at 13:46
marcus23
marcus23Author
Hallo,
I need a possibility to direct read/write access of the registers r0 ... r15 from my c-application.
Because direct after reset (in the startup assembler file) I store the value of the LR (r14) in r11. In my application I would like to analyze this value to detect a reset (then the value should be 0) or a software-reset (done by jump to address 0x40000000).
Regards.
