babidesai123
Aug 13, 2003 7:46 AM UTC
difficulty in accessing Port B in MCU I/O mode
Posted on August 13, 2003 at 09:46
babidesai123
May 17, 2011 9:55 AM UTC
Posted on May 17, 2011 at 11:55
hI,
I AM ABLE TO ACCES THE PORT b. i got my mistake.....
purvi
babidesai123
I tried to access the port B in MCU I/O mode.But i couldn't access the same...
e.g
mov a,#0x00
mov dptr,#CONTROL_B
movx @dptr,a // MCU I/O mode
mov dptr,#DIRECTION_B
movx @dptr,a // as i/p port
mov a,#0x41
mov dptr,#DATAIN_B
movx @dptr,a
after this i tried to read the port B using
mov dptr,#DATAOUT_B
movx a,@dptr // read the data_out for poret B
& transmit the same on serial port....
but port B is always low...all bits=0
i would like to know where i am going wrong..
moreover the DATA_IN for port B is 0x01 (reg offset address or 0x02???)
yu-jun
I don't know which wrong you said:
you send #0x41 and want get the data through read port B?
Is it your means?
If it is, you may get the same data, or not. because the data is sent, but that you have read has changed by the peripheral.
