s_alimelli
Feb 18, 2009 5:51 AM UTC
Debug Error
Posted on February 18, 2009 at 06:51
Debug Error
    bassinux
    May 17, 2011 1:02 PM UTC
    Posted on May 17, 2011 at 15:02
    which version of STVD You use, actually there is Pack16.
    make sure about the vactor table address that you use.
    Best Regards
    Bassinux
    s_alimelli
    I use Cosmic Compiler + Stvd for debug, Now I canot debug my source because my program counter fall into a unlimited loop in address 0x3e at Ram. I donot have this problem previousely. I donot know what is incorrect I know it must go to boot rom address but it donot. I use a 16k limited cosmic compiler vergen but my program doesnot exceed its limit. sometimes I see option byte error. I can Program with Ride software but I need stvd debug. I use Rlink dongle (Raisonance Programmer) I will be nice if you help me. best ,
    Best Regards,
    mozra27
    Can you please try this configuration and keep me informed:
    - disable all optimizations ''disable for debugging -no''
    - memory models: long stack(+modsl0)
    - start-up file: crtsi0.sm8
    mozra
