nambip2
Apr 22, 2005 5:15 AM UTC
Data EEPROM & Flash memory protection
Posted on April 22, 2005 at 07:15
nambip2
nambip2Author
Apr 17, 2005 11:55 AM UTC
Posted on April 17, 2005 at 13:55
I like to use the ST7FLITE09 .This has 128 bytes of data EEPROM which i like to utilize fom In application programming .At the same time i like to have the security enabled - ie flash readout proection.My doubt is that when i configure the device for flash read out protection will i still be able to use the data EEPROM for read and write?
venkateswara
Apr 19, 2005 9:16 AM UTC
Posted on April 19, 2005 at 11:16
Yes, You will be able to still write or read the EEPROM through In-application programming. The read-out protection is applicable for ICC mode. You can see the Flash programming refernce manual on the ST internet.
Hope this helps.
bye
venky
nambip2
nambip2Author
Apr 21, 2005 12:19 PM UTC
Posted on April 21, 2005 at 14:19
Can you send the document number for the Flash programming manual ?
Prasanna
venkateswara
hi,
find the attachment i downloaded from internet...see page..
________________
Attachments :
1072800075.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Gf&d=%2Fa%2F0X0000000bWO%2FqW_tofKoCLG4gvzHNXclPy1857QNe1X7yYJPc.nFqAw&asPdf=false
