luca239955_stm1_st
Sep 29, 2010 1:03 PM UTC
CxSTM8 v4.3.5 now supports STM8L eeprom
Posted on September 29, 2010 at 15:03
    lowpowermcu
    May 17, 2011 1:10 PM UTC
    Posted on May 17, 2011 at 15:10
    Hi luca,
    What is the utility of using such memory types ?
    I am used to play with mcu and never I got such types ?
    what is the advantage of placing varaibles there ?
    Perhaps such questions should be asked to ST, why they are implementing eeprom in their micro ? (I think that STM32F sereis doesn't embedd eeprom)
    Thanks in advance.
    with regards,
    MCU Lüfter
    luca239955_stm1_st
    I think the STVD team is making the necessary modifications so that the automatically generated linker file works ok, but I don't know if this has been released yet.
    Whatever way, if your STVD does not generate a correct linker file automatically, you must edit it by hand.
    Regards,
    Luca
    641351125
    Luca
    the manual describe like this''you must link with the extra library libl.sm8 placed
    before
    the standard libm.sm8'',but how to do it in the STVD? I would like to know the setting.
    Calvin
    luca239955_stm1_st
    you would usually store in EEPROM those data that you don't want to loose when you turn off the application: telepohone numbers in a mobile phone, running statistics in a car engine... a lot of examples could be made.
    Regards,
    Luca
