stefano239955_stm1_stmicro
May 17, 2011 7:31 AM UTC
Posted on May 17, 2011 at 09:31
I'm playing with CAPS.
I found a discrepance in the
constant definition used in the STR91x library and
the include file produced by this application.
The timer section is defined as _TIMx in the library
but the CAPS produce an include file with _TMRx :-Y !!!!!
Stefano
anis
Hi Stefano,
You are correct, _TMRx is used instead of _TIMx, this will be corrected in next release of CAPS.
Thanks,
STARM
