roger_lynx
Apr 11, 2007 3:35 PM UTC
Crystal selection/oscillator considerations
Posted on April 11, 2007 at 17:35
roger_lynx
May 17, 2011 7:31 AM UTC
Posted on May 17, 2011 at 09:31
Would you please point me at the part of the STR9 documention which deals with crystal selection for the main internal oscillator?
I can not seem to find any reference to the crystal properties/specs that are required by the STR9's oscillator to work properly.
For example: crystal's cap. load CL, xtal's ESR, or the values for ext. parallel capacitors from MCU's terminals X1_CPU/X2_CPU to ground.
Any help in this area is appreciated in advance.
Thanks.
sjackson
I saw nothing concerning main crystal ESR, load capacitance, etc in the STR9 getting started guide.
roger_lynx
I missed that. Thank you.
halim
I suggest to look STR9 getting started hardware.
With best regards,
Punto
sjackson
Thanks for your crystal specs. It will serve as a good starting point for me.
roger_lynx
'cause it ain't there, I thanked for the excellent koan.:-]
..but my design works with a crystal having these specs:
f = 12 MHz
C_load = 18 pF
C_shunt = 7 pF
ESR = 100 Ohm
