raja1
crtsi.s file startup script for stm8A
Hello all. I am looking for an example startup script to perform a few initialization tests.
I came to know that in  https://usermanual.wiki/Document/CXSTM8UsersGuide.1100875490.pd
Initializing data in RAM section there is a startup script.
I would like to know if there is any tutorial for the same.
If there are any code examples, kindly share them with me.
    raja1
    raja1Best answer
    I am looking for the startup script. Yes, I have found the crtsi.s startup script in the COSMIC folder.
    AA1
    Senior III
    August 3, 2023
    Do you want a startup script or a linker script?
    If you are using COSMIC compiler, read the manual and see Examples and Hstm8 folders. The file crtsi.s is in Hstm8 folder.
    raja1
    raja1AuthorBest answer
