ulivo15
Jul 21, 2004 6:38 AM UTC
CPU Frequency. What is it?
Posted on July 21, 2004 at 08:38
ulivo15
ulivo15Author
Jul 19, 2004 5:08 AM UTC
Posted on July 19, 2004 at 07:08
Pardon, i'm a beginner.
The CPU Frequency is equal to the RC oscillator? (In the st7lite09 there is an internal RC Oscillator (1 MHz): is the CPU Frequency at 1 MHz?)
I need a baud rate of 31250 with a st7lite09. I can make it with the SPR bits, but how to set the CPU Frequency?
What are the ways to modify the CPU Frequency?
I thank you - Grazie mille - Je vous remercie
anshul
Jul 20, 2004 6:34 AM UTC
Posted on July 20, 2004 at 08:34
Yes, you are perfectly right the CPU frequency is equal to the RC oscillator frequency and it will be 1 MHz in ST7FLite09 when you use the Internal RC oscillator tuned to 1MHz.
In order to get a baud rate of 31250 you can use the Internal RC for 1MHz Fcpu and then select a /32 prescalar.
anshul
You can refer section on Internal RC adjustment on page 24 of Lite0 datasheet for a better understanding.
