laffer
Dec 22, 2009 11:12 AM UTC
COSMIC Type Cast Problem
Posted on December 22, 2009 at 12:12
    krzysztof239955_st
    May 17, 2011 1:06 PM UTC
    Posted on May 17, 2011 at 15:06
    The setting Display Item from Decimal on Standard in debuger solved the problem.
    Kris.
    laffer
    lafferAuthor
    We have 2 issues during using COSMIC Compiler 4.3.1 16k Limit version and STVD 4.1.3, R-Link.
    First, we don’t have functional value through using Local Variable, when we use as above it shows different value on long_var.
    void main(void)
    long long_var = 0;
    float float_var = 0;
    long_var = 533485489;
    float_var = (float)long_var;
    while (1)
    http://www.insem.co.kr/100201/1_local.gif
    Second, Type Casting problem.
    long long_var = 533485489;
    void main(void)
    while (1)
    It showed wrong value on float_var as it was inserted Type Casting after we declared global variable,
    http://www.insem.co.kr/100201/2_cast_fail.gif
    however, it goes properly in main function as follows.
    long long_var;
    void main(void)
    while (1)
    http://www.insem.co.kr/100201/3_cast_success.gif
    We think it has a problem, isn’t it?
    luca239955_st
    also, when you work with local variables that are not actually used for anything, the compiler sometimes optimize them out: use globals or, at least, declare the locals volatile, to avoid this.
