matthieu1
Oct 2, 2009 3:35 PM UTC
Cosmic problem
Posted on October 02, 2009 at 17:35
Cosmic problem
    matthieu1
    matthieu1Author
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    I'm trying to compile a cosmic project on STVD, but the followings errors occured :
    #error cpstm8 C:\Program Files\COSMIC\CXSTM8_16K\Hstm8\mods0.h:0 FlexLM Invalid host
    The command: ''cxstm8 +debug -pxp -no -l +mods0 -pp -i''C:\Program Files\COSMIC\CXSTM8_16K\Hstm8'' -clDebug\ -coDebug\ ''c:\program files\stmicroelectronics\stm8sfwlib\fwlib\library\src\stm8s_adc2.c'' '' has failed, the returned value is: 1
    exit code=1.
    please help me,
    Matthieu
    luca239955_st
    you need a license to run the cxstm8. This license is free and you get it by sending your pc data (run lmreg.exe) to
    mailto:stm8_16k@cosmic.fr
    Once you get the license, you copy it in the /lic subdirectory of the compiler and you should be able to compile.
    Did you do these steps already, or not yet?
    Regards,
    Luca (Cosmic)
    matthieu1
    matthieu1Author
    What are you implying by ''Step5: Add your free license path to ''LM_LICENSE_FILE'': '' What i have to do exactly. (Pardon me I'm a novice)
    Many thanks
    Matthieu
    mozra27
    Hi Matthieu,
    You should add the local configuration to be able to access free cosmic license.
    Please follow these steps:
    Step1: Go to ''Start -> run'' and type ''regedit'' (Registry Editor is now opened)
    Step2: Go to ''HKEY_LOCAL_MACHINE ->SOFTWARE -> FLEXlm License Manager''
    Step3: Add New Folder ''FLEXlm License Manager'' if not exist
    Step4: Add new string value name ''LM_LICENSE_FILE'' if it doesn't exist (floating menu then ''new -> String Value'').
    For example C:\Program Files\COSMIC\CXSTM8_16K\License
    Regards,
    Mozra
