wuyue0510
Apr 16, 2014 3:20 AM UTC
cosmic or st visual develop problem?
Posted on April 16, 2014 at 05:20
to be migrated, sourceId: 2819:B33A1EDD-DCC4-4087-BEFC-454F45B13F1B
    chen
    Apr 16, 2014 3:16 PM UTC
    Posted on April 16, 2014 at 17:16
    Hi
    You are doing a bit wise compare on a 32bit number on a 8 bit processor!
    Examine what the compiler has generated.
    Off the top of my head - it would have to do bit wise compares on 4 bytes.
    jdf25252
    Apr 16, 2014 3:46 PM UTC
    Posted on April 16, 2014 at 17:46
    There's nothing wrong with the compiler or IDE here. 0x141A0714  & 0x141A0200 really does equal 0x141A0200 check it out with calc.exe.
    You need to reevaluate what it is you're trying to do.  If you're trying to look at a part of the command_code you should use the same mask for ALL the compares.
    jdf
    wuyue0510
    wuyue0510Author
    Apr 17, 2014 2:11 AM UTC
    Posted on April 17, 2014 at 04:11
