balmukund66
May 27, 2013 9:48 AM UTC
COSMIC LKF File
Posted on May 27, 2013 at 11:48
Hi All,
I want to execute some command in .lkf file for COSMIC Compiler condionally.
is it possible??
Pseudo code is as below:
#ifdef TRUE
obj\libisl.sm8
#else
obj\libis0.sm8
#endif
Balmukund Prasad
    luca239955_stm1_st
    May 28, 2013 6:44 AM UTC
    Posted on May 28, 2013 at 08:44
    no, it is not possible.
    Strange question though: what did you want to do with that?
    Regards.
    balmukund66
    May 28, 2013 8:55 AM UTC
    Posted on May 28, 2013 at 10:55
    Hi Luca,
    Thanks for confirmation.
    Actually i wanted to change memory model dynamically based on some MACRO.
    Thanks & Regards
    Balmukund Prasad
    luca239955_stm1_st
    May 28, 2013 2:08 PM UTC
    Posted on May 28, 2013 at 16:08
    For that I would suggest you use a makefile/batch/script (depending on your OS and your preferences) that, depending on the memory model chosen
    - calls the compiler with the proper command line
    - use different linker files for every memory model
    Regards.
