jagspaul
COSMIC LICENSE error
Posted on June 13, 2015 at 18:18
I have got cosmic license file and copied it to
''license'' sub-directory of the compiler.
But while compling getting error as
 FlexLM System clock has been set back.
I contacted to cosmic they replied as
This message means that either you have changed the clock/date system on your PC or you may have some files that have a date after the current system date. The Flexnet system is very sensitive.
What you could do is to remove or change the date of that file(s), or remove the COSMIC_LICENSE_FILE registry key and re-run the compiler.
As the software is free, there is no direct support. Support is done via the discussion forum on
https://my.st.com//public/STe2ecommunities/mcu/default.aspx
#cosmic-license
    luca239955_stm1_st
    Posted on June 13, 2015 at 21:53
    as you have been told, search for files with a date ''later'' than the current date and remove them.
    Regards.
    jagspaul
    jagspaulAuthor
    Posted on June 13, 2015 at 22:20
    search on which folder? cosmic installation or my project source folder?
