Chan.Calvin
cosmic compiler error?
hi
Comsic STM8 compiler suite version: 4.4.12.
I am using this compiler version together with ST's STVD.
In the sample code attached, with line 13 conditional define set to 0, the compiler yields compilation error (my intended implementation), and the alternate fix is demonstrated with conditional define set to non-zero (my temporary fix).
Can any users or cosmic support check if this is actual the same as what I experienced to ensure this is actually a compiler issue, or any option setting issue.
Rgds
Calvin
