burakakcasu
Aug 12, 2008 8:22 AM UTC
Cosmic Compiler bug
Posted on August 12, 2008 at 10:22
Cosmic Compiler bug
burakakcasu
Aug 8, 2008 6:34 AM UTC
Posted on August 08, 2008 at 08:34
Hi.
I'm trying to learn Cosmic Compiler program. For programming ST7 microcontrollers.
I have a problem about Compile and build.
I work with example program. I press compile or build button and i get this
error message
''Can't Access File:IDEABLD.BAT in Project Directory. Check Access Rights.''
I use Windows Vista as operating system.
Could you help me.
Thanks.
Burak Akçasu.
luca239955_st
Aug 11, 2008 3:23 AM UTC
Posted on August 11, 2008 at 05:23
as the error message says, make sure you have full rights on the project directory. If you have no clue, log in as admin and try again.
Regards,
Luca (Cosmic)
burakakcasu
Aug 12, 2008 1:59 AM UTC
Posted on August 12, 2008 at 03:59
Quote:
Regards,
Luca (Cosmic)
Thanks for your answer. But it didnt work. I have full rights on project directory but still i get same error message.
I think it is about Windows Vista.
Thanks again. I think i must return Windows XP :).
luca239955_st
Aug 12, 2008 5:46 AM UTC
Posted on August 12, 2008 at 07:46
probably a wise choice :)
However, of course, we have tested the compiler on Vista ans it does work.
Good luck.
Luca
burakakcasu
thanks.
huayangflorida
May 17, 2011 1:31 PM UTC
Posted on May 17, 2011 at 15:31
Hi, I saw the posted problem but didn't see solution.
Could anybody help?
error message
I use Windows-7 64bit as operating system.
xander2015
Jan 12, 2012 1:27 AM UTC
Posted on January 12, 2012 at 02:27
you should use 32bit system.
wolfgang239955_stm1_st
Jan 23, 2012 8:29 AM UTC
Posted on January 23, 2012 at 09:29
I failed to start the Cosmic Compiler when residing the source files on our intranet. After I've transferred all my files to my local drive - there has been no problems any more.
Take it just as a suggestion,
WoRo
