krzysztof239955_st
Oct 2, 2009 4:41 AM UTC
Cosmic
Posted on October 02, 2009 at 06:41
Cosmic
    luca239955_st
    May 17, 2011 1:04 PM UTC
    Posted on May 17, 2011 at 15:04
    if you don't *see* the value you expect in a local variable is probably just an optimization. If the value is actually not correct (for example in a subsequent use of the local variable) than it is another issue.
    Please post an example to clarify.
    Regards,
    Luca (Cosmic)
    krzysztof239955_st
    I use ST Visual Develop with Cosmic compiler. If I declare the local variable (in main.c), the returned value never correct, if it is declared as global variable, the returned value is correct, why?
    krzysztof239955_st
    Hi _luca,
    It pretended me the problem to be dissolve.
    krzysztof.skoczek
