Corruption / Erasing of memory contents from M95256-A125
Hello All,
M95256-A125 chip is used as external EEPROM for our automotive product .
The product is in field use  & recently some field issues are reported
On analyzing field return unit , it's found that the most of the data in EEP chip is either corrupted or in erased  .
  • What are the possible cases where such erasing / corruption can occur
  • Does any environmental conditions can cause this problem
Andrew Neil
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
Software faults/misbehaviour; hardware issues.
Possibly.
Are you sure that the product remains within the chip's environmental specs?
"environmental" effects could include EMI/EMC, poor power supply, etc ...
SaraBAuthor
Hi Andrew,
Thanks for the info
The chip was with in the environmental specs.
Could you elaborate the probable use case of Software faults/misbehaviour , hardware issues.
Andrew Neil
How are you sure of that?
Automotive is a notoriously harsh environment.
Software which incorrectly writes to the memory, or writes incorrect data, or accidentally/incorrectly erases the device.
These could be due to design flaws, implementation flaws, or both.
You need to debug your software.
@SaraB wrote:
hardware issues.
Noise; interference; unstable power; brownouts; etc ...
