jocelyn
Jan 21, 2005 6:59 AM UTC
copy the memory of a ST62T65CM6
Posted on January 21, 2005 at 07:59
jocelyn
jocelynAuthor
Jan 7, 2005 6:42 AM UTC
Posted on January 07, 2005 at 07:42
Hi
if the protect bit is low, is it possible to copy the memory of a ST62T65CM6 (used as master devices) using ST6 EPROM Programmer (used in Stand alone mode)?
regards.
Jocelyn
vikas2
Yes, if the read protection option bit is not set,you can read the program burned in the device. There is one Read button availble for this in Winee(Window EPROMER),which is freely available on stmcu site .
