parveen
Contant pointers in C
  • December 22, 2003
  • 6 replies
  • 1101 views
Posted on December 22, 2003 at 05:36
parveen
parveenAuthor
Posted on December 11, 2003 at 00:44
Has anyone tried to use pointer declaration with const prefix in C. Normally any declaration with const prefix goes to ROM or const segment but when I declare a pointer array with const prefix it goes to data segment.
const unsigned char * MyPtr[]={};
I want MyPtr to be stored in ROM
I have tried this with both Metrowerks and Cosmic compliers
Thanks in advance,
Regards,
praveenG
seeguard
Posted on December 11, 2003 at 06:17
Try this:
#pragma INTO_ROM
then look in the MAP file and check:
- VARIABLES:
MyPtr address len ( 2) ROM_VAR
atz
parveen
parveenAuthor
Posted on December 11, 2003 at 10:53
Thanks a lot
It really works for Metrowerks. Could you suggest some method for Cosmic compiler also.
Does anyone knows how to do the same for cosmic compiler????
Thanks again
Regards,
PraveenG
sjo
Posted on December 11, 2003 at 20:33
To make the pointer constant in cosmic do the following:
const unsigned char * const pString = ''string'';
sjo
parveen
parveenAuthor
Posted on December 12, 2003 at 06:01
Thanks a lot
it works for cosmic also
Regards,
PraveenG
parveen
parveenAuthor
I recently found out that Metrowerks has one technical note on this topic
Refer TN102:Contant pointer and pointer to constant (Search TN102 on www.metrowerks.com)
Regards,
Parveen
[ This message was edited by: praveenG on 22-12-2003 10:07 ]
