schaeublinconsu
Constants in EEPROM ST7Flite0
  • October 21, 2003
  • 3 replies
  • 775 views
Posted on October 21, 2003 at 07:06
schaeublinconsu
Posted on October 11, 2003 at 15:36
How can I define constants with indart / assembler in the EEPROM.
Thanks and regards
hansjusch
parveen
Posted on October 13, 2003 at 04:52
With Cosmic compiler:
You can use @eeprom to declare variables in EEPROM
@eeprom char var1;
or you can use #pragma to declare all your variables in EEPROM
The compiler uses a runtime library for eeprom variable operations
With Metrowerks compiler:
You can define a different data segment for EEPROM variables and constants and then define this segment in .prm file
in source file use
#pragma DATA_SEG EEPROM_DATA
unsigned char var1;
in .prm file use
PLACEMENTS
EEPROM_DATA INTO EEPROM
refer to compiler manual for read write operations as they may require some EEPROM register settings.
Hope this Helps,
Best Regards,
PraveenG
schaeublinconsu
Dear PraveenG
Thanks for Your answer.
My concern are constants (like look- up tables or character- strings) directly programmed in the EEPROM with InDart / Assembler.
Kind regards
hansjusch
