tayfun
constant declaration
  • August 14, 2003
  • 3 replies
  • 841 views
Posted on August 14, 2003 at 11:10
tayfun
tayfunAuthor
Posted on August 14, 2003 at 07:47
When defining constant tables in Rom segment for ST72F324J6,
it maybe a chance or fault, I see that after defining
.SEGTAB1:
DC.B $FE
the read of SEGTAB1 first element results in $01.
If we define it as
.SEGTAB1:
DC.B 254 then read to it is OK.
Can you please advise it ?
Regards,
Tayfun
sjo
Posted on August 14, 2003 at 11:07
If you are using ST assembler then you need to declare your array as:
.SEGTAB1 ; remove :
DC.B $FE,$FF
to access the array:
clr X
ld A, (SEGTAB1,X) ; read first element of array
inc X
ld A, (SEGTAB1,X) ; read second element
Hope this helps
SJO
sjo
Forgot to mention make sure the memory declaration is not on the first column eg.
.SEGTAB1:
DC.B $FE,$FF
not
.SEGTAB1:
DC.B $FE,$FF
Note: Forum has removed spaces.
SJO
[ This message was edited by: sjo on 14-08-2003 14:42 ]
