lars2
Jan 6, 2010 9:49 AM UTC
Compiling in release mode not possible
Posted on January 06, 2010 at 10:49
    luca239955_st
    May 17, 2011 1:06 PM UTC
    Posted on May 17, 2011 at 15:06
    that's strange.. please post the command lines generated by STVD to the compiler for both cases.
    Regards,
    Luca (Cosmic)
    lars2
    lars2Author
    Dear,
    I programmed at STVD in C and used also some ST-firmware-functions. When I build the project in debug mode everthing is working fine.
    When I try to build the project in release mode there are many errors just building the first stm8s-firmware file ''adc1.c''. (Errors: bad struct, not defined ...)
    I'm using the STM8 Cosmic compiler and STVD 4.1.2!
    I hope this problem can be solved quickly.
    Regards,
    Lars
    lars2
    lars2Author
    Hi Luca,
    many thanks. Now it works. You gave me the right direction. The uC-type wasn't included in the Preprocessor Definitions in release options.
    Thanks and regards,
    Lars
    lars2
    lars2Author
    These are the messages from the output window.
    Regards,
    Lars
    luca239955_st
    I'm no STVD expert, since it's not a Cosmic product, but the list of include paths is different in the two cases, and the problem might come from there.
    Hope it helps.
    Luca
