giovanni239955
May 17, 2011 9:34 AM UTC
Posted on May 17, 2011 at 11:34
Hi Romain, the problem I think is in this statement:
'' else if ( (((unsigned int) NTC_TEMP_mis) < ((unsigned int) (PNTC_TEMP_mis + DELTA_TEMP_mis))) ||
(((unsigned int) PNTC_TEMP_mis) < ((unsigned int) ( NTC_TEMP_mis + DELTA_TEMP_mis))) ) ''
In fact, if I write (for test):
'' else if (TRUE) '' all works.
I will try to simplify it.
Only to make clear my situation, I'm porting an ST7 application (compiled with Cosmic) to an ST9.
Many thanks
romain2399
Please attach your adc.c file.
giovanni239955
Excuse me, my compiler generates this error:
Unable to find a register to spill
(insn:HI 81 80 83 (parallel[
(set (reg
F 291)
(reg
F 16 R0))
(clobber (scratch:SI))
] ) 54
abnormal program termination
gcc9.exe: Internal compiler error: program cc1 got fatal signal 22
gmake: *** [adc.o] Error 1
but I can't find a description of the error. Where may I find it?
Anybody can help me qhere to investigate?
Many thanks
