Mar 24, 2026 10:43 AM UTC
Clone ST-LINK Error: No STM32 target found!
Title edited to note that this is not a genuine ST-Link
11:19:26 : ST-LINK SN : 37FF71064E57343652791543
11:19:26 : ST-LINK FW : V2J46S7
11:19:26 : Board : --
11:19:26 : Voltage : 3.24V
11:19:26 : Error: Unable to get core ID
11:19:26 : Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
I am using a LoRa module E77-900M22S that has incorporated a STM32WLE5CCU6. Also i am using a ST-Link V2 mini connected to program the micro. I have connected SWDIO and SWCLK properly and the module has 3.24V so the problem its not the connections. I dont know why it doesnt detect the MCU.
Andrew Neil
Andrew NeilBest answer
Mar 27, 2026 11:27 AM UTC
Again, there is no guarantee that those will work properly (or at all) with ST's tools.
They are simply not supported.
You could try faffing around; you might get lucky - or you could just get a genuine ST-Link (or other genuine supported brand) and get on with your project ...
Andrew Neil
Mar 24, 2026 11:11 AM UTC
@AlexPCB wrote:
i am using a ST-Link V2 mini .
There is no such ST product as a V2 Mini - do you mean one of these ?
There is no guarantee that those will work properly (or at all) with ST's tools - see this.
AlexPCBAuthor
Mar 24, 2026 3:21 PM UTC
I am using one of those actually. There is any problem with it or should I use an original one?
Andrew Neil
Mar 24, 2026 4:49 PM UTC
Again, there is no guarantee that those will work properly (or at all) with ST's tools - see this.
Note also that the pinouts do vary.
That would remove one area of doubt and uncertainty!
Just be sure to buy from an Authorised ST Distributor - not Amazon, ebay, Ali, or similar
Andrew Neil
Mar 24, 2026 11:17 AM UTC
@AlexPCB wrote:
I am using a LoRa module E77-900M22S .
You mean this: https://www.cdebyte.com/products/E77-900M22S/2 ?
Have you checked with EBYTE for support: https://www.cdebyte.com/ContactUs ?
Please show your schematic for people to confirm.
A good, clear photo could also help.
You haven't mentioned VTARGET, GND, or NRST ... ?
Maybe EBYTE have locked-out programming?
AlexPCBAuthor
Mar 24, 2026 3:45 PM UTC
https://www.cdebyte.com/products/E77-900M22S/2 This is exactly the one that i am using
This is the schematic of the connection:
