afabilli9
Jan 18, 2006 6:07 AM UTC
Class in INDART_STX
Posted on January 18, 2006 at 07:07
Class in INDART_STX
afabilli9
afabilli9Author
Jan 16, 2006 11:29 AM UTC
Posted on January 16, 2006 at 12:29
I, a question about assembler using STVD7 last version.
I have make an error but the assembler not send a message, i have declared 2 class at same adress
WORDS
segment byte at FA00-FA81 'eeprom' (file xxx.asm)
WORD
segment byte at FA81-FFDF 'rom' (file yyy.asm)
The STVD assembly without error and warning but software resultying not work.
There are a solution for this problem?
Thank and sorry for my bad english
franco
Jan 17, 2006 10:29 AM UTC
Posted on January 17, 2006 at 11:29
Which micro are you using? Why are you doing these 2 class? However there is an address cross error (FA81)
afabilli9
afabilli9Author
Vedo che sei italiano e quindi vado con la lingua madre al posto del mio pessimo inglese.
Il problema è nell'assemblatore che non vede la sovrapposizione delle 2 classi dichiarate!
Volevo segnalare questa anomalia e capire se esiste la possibilità di evitare il problema.
Ti ringrazio per il tempo accordato.
