Birdo
Changing ADC to channel that is not configured by option byte.
Currently I am programming STM8AF5288.
With option byte OPT2.AFR5 the AIN3, AIN2, AIN1 and AIN0 can be remapped to the correct port.
Do I need to check if this bit is set correctly before I change the ADC channel to one of those AINx?
What will be measured if the bit is set wrong?
