td.kirkham9
Nov 20, 2007 5:38 AM UTC
cant stop running
Posted on November 20, 2007 at 06:38
cant stop running
m_tibu
May 17, 2011 7:47 AM UTC
Posted on May 17, 2011 at 09:47
I had similar problem, but different board and same environment.
I was not able to halt the target and when I issue for first halt command and then poll commnad by the openOCD interface I see:
target running
I went through some hardware debug and I saw that my reset generator was broken, it stuck to gnd the reset and I was not able either to run or to debug. I think this happends because when you use a debug cable (wiggler, FLASHLink and so on) there is a net conflict between the reset generator and the Jtag interface that is trying in debug to reset the micro by the reset line.
Take a look at your hw and check if once the debug cable is plugged in the reset line is moved correctly.
In my case I removed the reset generator and changed it with an RC net.
Good luck.
Marco
td.kirkham9
I have a comstick that has an embedded USB that I debug through. I debug through OpenOCD and Hitex. I have a target running that I can halt in either debugger. I have tried the commands halt, reset etc and they have no effect, it keeps on running.
Does anybody know how to stop my device?
Many Thanks,
Tom
