silvan
Aug 21, 2006 9:56 AM UTC
Posted on August 21, 2006 at 11:56
Hi all!
I just checked the HW behavior regarding this bit-shift stuff.
When you write an id (id28:0) to the registers
A1R: (id15:0)
A2R: (id28:16)
you get the following on the physical bus:
(SOF)(id28:18)(SRR)(IDE)(id17:0)(RTR).....
So, if this is what the application requires, the bit-shifting macros from the library are not required.
