Riyad Al-Ali
Aug 30, 2019 8:42 AM UTC
Can i find libraries for LCD, Keypad, and other peripherals in Keil ?
when i am using 8 bit microcontrollers, i use compilers that have a lot of libraries to make my work in programming the micrcontroller very easy, e.g lcd library and a lot of libraries so the development of my code will be easy, in fact i am trying to move to 32 bit, so i would like to ask such these libraries is available in keil ? or i must build the libraries for interfacing other peripherals? can i find libraries for LCD, keypad and other things ?
thanks?
Pavel A.
Sep 3, 2019 11:00 PM UTC
Just replace "Keil" with "Google" and yes, you can find there everything that exists under the sun.
Or you can find somebody who will create for you what you need.
-- pa
