hj_it
Apr 26, 2013 7:15 AM UTC
Booting Linux or U-Boot via USB boot on SPEAr320
Posted on April 26, 2013 at 09:15
Hello
Is it  possible to boot Linux Kernel via the  USB boot mechanism in the SPAEr320 CPU?
If yes, what tools are available to generate an image for a bootable USB stick? I hope to get at least a link to an approbriate application note.
 Heinz
#usb-boot
jonazaza
Apr 5, 2014 7:59 PM UTC
Posted on April 05, 2014 at 21:59
hi I am really having problems with uboot. I am using hyperterminal and a usb to serial converter. I press space bar just after a hard reset but nothing happens
Osto
Senior
Sep 22, 2014 1:10 PM UTC
Posted on September 22, 2014 at 15:10
I dont know, if you already solved you problem but you should test it with a pc with dedicated RS232 interface or with a RS-232 PCI-Card. Almost all USB->Serial interfaces are not working for this purpose. You will have a lot of problems.
