dominik2399
Jan 12, 2010 1:13 PM UTC
BLDC sensor based Motor control with the STM8S
Posted on January 12, 2010 at 14:13
    dominik2399
    May 17, 2011 1:03 PM UTC
    Posted on May 17, 2011 at 15:03
    Hello
    I'm searching a motor control library to control a BLDC motor with hall sensors and direct communtation. I'm working on a STM8S and need this library or C-Code as soon as possible. Can you help me? Or do you have a library for the STM32 or another type, so I can modify the code for the STM8S.
    Thanks a lot
    Regards, Dominik
    abelmeg
    Its not .exe. It is Zipped file containing .h .c and workspace files. If you want to know more about the library look
    http://www.st.com/stonline/products/literature/um/15773.pdf
    regards.
    m_kisacanin
    Is this supposed to be an (Windows) executable?
    Libraries usually come as ''bunch of .h and .c'' in a clear text/folder structure.
    Not that I'm paranoid (well I am), but don't like running someone's else exe on my machine :)
    abelmeg
    The library you're looking for is found at
    http://www.st.com/stonline/products/support/micro/files/stm8mcfwlib.zip
    regards..
    m_kisacanin
    The file comes as a zip archive, but inside the archive is
    STM8MC-KIT_1.0_090703.exe file (executable as mentioned before).
