will2
Mar 26, 2010 3:36 PM UTC
bidirectional GPIO on STM8?
Posted on March 26, 2010 at 16:36
    will2
    will2Author
    May 17, 2011 1:07 PM UTC
    Posted on May 17, 2011 at 15:07
    After playing around with this some more, I found that initializing the Port E pins as open-drain outputs, I can still use PE7 as an input to watch when the LCD is finished processing an instruction.  I set the pin high, and then sit in a while loop while watching for the msb to clear in the input data register for port E.  Seems to be working fine now...
