egartrell
Apr 23, 2010 6:31 PM UTC
Battery-backed RAM problem
Posted on April 23, 2010 at 20:31
egartrell
egartrellAuthor
May 17, 2011 8:00 AM UTC
Posted on May 17, 2011 at 10:00
So, my rep is exaggerating...nobody is using this?
baranovus
Hello, clive1.
I tried to make battery backup but also failed. I work in IAR. I declare variable foo __no_init,  somewhere in program assign foo = 0x85 and print it out at the beginning of main. It shows foo = 0;
But RTC itself works. At the beginning of hardware initializations I call:
  SCU_APBPeriphClockConfig(__RTC,ENABLE); /*enable RTC clock*/
  SCU_APBPeriphReset(__RTC,DISABLE);      /*RTC out of RESET state*/
and  after that:
  RTC_DeInit();
  RTC_SRAMBattPowerCmd(ENABLE);
Could you give a hint, what I'm missing?
Thanks.
Most of the people coming to the forums have problems, the lack of traffic is probably a good indicator. The STR912 project I worked on has been deployed.
